It is currently Thu Jul 10, 2025 7:52 pm
 Post subject: bridge repair
PostPosted: Fri Aug 23, 2013 1:08 pm
Last Name: Meier
City: Alliance
State: NE
Zip/Postal Code: 69301
First of many likely ridiculous questions, thanks in advance for your patience.
When using heat to release a bridge that needs to be reglued should I be concerned about the bridge plate and bracing also loosening from the heat? Maybe clamp those up as the top cools once the bridge is off?
 Post subject: Re: bridge repair
PostPosted: Fri Aug 23, 2013 2:55 pm
Dang! As many bridge removals as I've done, and I never gave a thought to the plate underneath.
GOOD QUESTION!
PostPosted: Fri Aug 23, 2013 8:59 pm
First name: Big
Last Name: Jim
:shock: Excellent question ! Thus far I have seen no issue , however I am a relative newbie. I have about 5 under my belt and as was said I never gave that a thought .
I hope more people chime in on this .
PostPosted: Mon Aug 26, 2013 7:12 am
Last Name: Salvi
City: Adelaide
State: South Australia
Zip/Postal Code: 5000
Wood is one of the best insulators out there. I often feel the plate, and when it's warm, you know the bridge will pop off. You can do it cold too. Do you know that trick?
PostPosted: Mon Aug 26, 2013 9:26 am
First name: Big
Last Name: Jim
Enlighten us please ! [:Y:]
PostPosted: Mon Aug 26, 2013 11:03 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
No, NOT the pop it off with a hammer trick!
Well, I guess it works when it works... wow7-eyes
edit: I thought Steve would be back with his technique, but here's the story.
Glue is not very strong in shear, so putting a block in front of the bridge and smacking it with a hammer will cause the glue joint to fail. I've never done this, and wouldn't recommend it, but others have had sucess with this technique.
PostPosted: Tue Aug 27, 2013 4:38 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I have always been conscious of this, I also worry about loosening the neck block from the top when heating and lifting the fret board extension. But I am happy to say I have not seen any issues...but yes to me it is a concern. I use only as much heat as needed and work as quickly as I can in these instances.
Brian
PostPosted: Wed Oct 02, 2013 8:50 am
Last Name: Salvi
City: Adelaide
No you don't shear it. You modify the chisel to get it to sit flatter to the top and you gently tap around the perimeter of the bridge a few times and eventually the sound of the tap changes dramatically....ok it's a shear, but a gradual one. Use a razor blade to cut the fibres holding on underneath. Clear as mud? It does work quite well. And it's neat. It's how Martin did it/ does it. At least they did back in day when I was there. It's really easy as well.
PostPosted: Wed Oct 02, 2013 11:47 am
First name: Rodger
Last Name: Knox
City: Baltimore
That make perfect sense, and that is a method I will try!
